1 - 10 of 10 Posts
There are several retailers in omaha that sell the 73" mitsubishi DLP. They usualy look really dark especially around the edges.
However I saw one that was properly calibrated and I was honestly impressed with the picture quality and the color clarity...so I stood there and looked at it for about 20 minutes.
Keep in mind that I was about 12ft away from it so I was the recomended distance...
but...
After that time I felt kind of nauseated and had a bit of a headache...is this the rainbow effect I have heard about? I always though that this only happened with LCDs...and I found it unsual because I've stared at a 63" samsung DLP and did not have the same issues.
LCD do not have rainbows.(RBE)
I don't know if RBE causes headaches.
Did you see flashes of color or trails looking like rainbows?
Discussion Starter #4
no color streaks...It could be the lighting that best buy uses looking at the tv under those lights may have caused it.
It could have possibly been caused by RBE without you taking notice. Not sure how exactly it works.
I would go to another store that has one and unfortunately possibly punish yourself again to see if it a consistent reaction which would mean it was the display.
I have never noticed or been effected by the RBE, but the LED DLP sets from Samsung supposedly eliminate it. We have a 67" model and my daughter has 61" model. All of the family and friends have never complained or been effected adversely.
I never see them either, not even on lamp based DLP's.
But it is still there to those who are affected from whta I read. It just cut the amount/severity down I believe.
That's why I reccomended going to a second store to make another evaluation....all I could think of to reccomend.
I have heard of this but it's supposed to be rare. I believe it is caused by vertigo from the flashing image and color processing done by the brain.
Found this after a quick google search...
In an airplane at sunrise or sunset, a pilot may encounter flicker vertigo. In the most rare of cases, flashing lights at certain frequencies can trigger seizures, nausea (this one includes me), convulsions, or unconsciousness.
1 - 10 of 10 Posts
