1 - 1 of 1 Posts
AV Sound Lab said:
These tower speakers are being designed primarily for nearfield use, but would be more than sufficient for most as mains. The primary goals for this design were:
  • Inaudible distortion levels
  • A minimum of 30dB attenuation of cabinet resonance.
  • Large dynamic range in the event that these are used as studio monitors.
  • Maximum linearity such that there are no deviations from average more than 1dB (30Hz-20kHz +/-1dB).
  • Wide polar response that closely matches on axis response in the event that the loudspeaker shifts duty from nearfield use....
Read more.
This thread is for all discussion of the Nearfield Monitor build found on AV Sound Lab.
1 - 1 of 1 Posts
