1 - 4 of 4 Posts
Hi,
I have done some basic 7.1 Home Theater setups before... Trying to do a multi-room speaker system for one of my friend... I was planning to do it using a Monoprice 108232 4-Channel A/B Speaker Selector with Volume Control, which will give them control over individual speaker pairs. Came across the In-Wall Impedance Matching Volume controllers and wondering what additional control it gives over the former one… one obvious reason I can understand is that it can be placed on individual rooms and can be used to control volume without reaching the main controller.
I might have got the basics wrong, so do correct me if I need the impedance matching volume controller by default for a multi-room speaker setup.
Rgds,
Sri.
Plain ole user
Being able to control the level in each room is much more convenient, and if you use impedance matching controls there is no need for the switcher.
1 - 4 of 4 Posts
