1 - 12 of 12 Posts
Hi everyone!
My mic stand busted at its 360-degree swivel joint (in the horizontal plane), which is threaded but won't seem to screw back on. I have to basically push it down so that it snaps into place, only to have it snap back out again after only a few swivels. Sorry, I don't remember the brand, but it was only around $25.
Is this a case of you get what you pay for? I don't mind spending more for quality, so please help me choose a decent boom stand. I say "boom" because it's difficult to maneuver the stand in the small space I call my HT. I would like to be able to keep the stand on one side of the LP and move the mic through all room-correction measurement points. I think a 3-foot boom should do it. I'd also like for the stand not to fall over when fully extended, though I think it helps to have one of the tripod's feet under the boom to help support it in those situations.
TIA :bigsmile:
Discussion Starter #6
Try DR Pro
I went with the DR Pro, very sturdy & priced right. Got it at Guitar Center on sale!
(sigh)... maybe someday.
The GC I visited was out-of-stock, and I need one this weekend, so I got a mid-market Pro Line MS220BK with a 3 year warranty.
Super Moderator
Too late I see, but I was going to suggest that if Guitar Center didn’t have any replacement booms, you can find them on line at Sweetwater, ZZ Sounds or Musician’s Friend. You might want to return the stand you bought and go that route anyway. It has lots of bad reviews on Guitar Center’s web site. Either that or wait until your local GC has the DR Pro in stock. After all, you did say you wanted a "better" mic stand... :)
Discussion Starter #9
:gulp: So that's why I didn't sleep well last night.
Thanks for the heads-up! I'll check with another branch across town when they open later today. Hopefully, I can exchange it there instead of having to return to the original branch.
Discussion Starter #11
Thank you so much, Wayne, for weighing-in even though you knew I'd pulled the trigger. The DR Pro is substantially heavier and sturdier than the other models I tried, and it comes with a 5 year warranty. That alone was well worth the trip across town to a different Guitar Center branch. They even exchanged the one I bought yesterday instead of making me drive back to the first store!
And thank you too, cullingman. I'll keep that one on my radar in case I need a backup.
Super Moderator
Excellent, Lou! And Kudos to AudiocRaver the recommending the DR – I don’t pay enough attention to mic stand brands to know one from another. Heavier-duty and with a five year warranty - good chance you'll never have to buy another one, at least for as long as a you only use it to take REW measurements.
Regarding your first one - I tell ya what, you couldn’t imagine a more light-duty use for a mic stand than occasional residential use taking REW measurements, and using a lightweight mic to boot (as compared to say, a heavy hand-held wireless). Any stand that can’t hold up to that –it’s simply disgraceful. :rolleyesno:
1 - 12 of 12 Posts
