S
stanwalters
·Guest
Hello all,
I've been doing searches of the archives and have found some info on this but nothing where advice was given on a system with larger speakers. I'm looking at options for mounting my front channel Paradigm Studio 100s (circa 1999 model) around my 100" screen. My current plan has a Servo (15") sub on the far right of the 117" wide space. Due to this decision, having the 100s standing on the floor (which puts the tweeters about 40" up) is not possible. My two remaining choices are to put them on shelves starting 22" or more high, which will push the tweeters up to a questionable 62"+, or mount the 100s horizontally directly under the screen, sandwiching the cc between them with about an inch to spare between each of them. Anticipated use is 95%+ movie viewing, and there are two rows of 4 seats 8 and 11 feet from the screen, the second row on a 5" riser (limited by ceiling height here).
My questions are:
- Which option is preferable for the intended use?
- Would the vertical disparity between the cc to the L/R using the shelf-mounting option be mitigated by mounting the speakers themselves 'upside down' bringing the tweeters within a foot or so vertically?
- Various threads advise against horizontal placement, but almost all say "depends on the speakers being used". Anyone with this knowledge have an opinion on horizontal mounting of the tall Paradigms?
- For HT use, if the horizontal option is preferred, would they best be oriented with the tweeters outboard (where they'd be ~80" apart) or inboard (less than 30" apart)?
- Right now, the design has a storage area in the space under the CC. I could conceivably eliminate this from the design and move the Servo inward, between the L/R speakers, which would allow the 100s to be stood upon the floor at the design-intended height, however I'm not sure what the effect of having the sub in the center of the rig would be (and whether whatever the effect, if it would not be outweighed by the advantage of more standard placement of the L/R speakers).
Thanks in advance for the help!
My questions are:
