Hello,
I have a TheaterWide 42H81 which was still kicking it pretty well, until it began dropping audio and video on random.
The audio will kick out at go to a loud static (relative to the volume setting on its speakers). It also drops video in the sense that it will display typically a single color (mostly green or purple) in a static type fashion.
Here are some links to YouTube, with videos showing each of these two problems:
Audio Problem -
Video Problem -
Please let me know what you think it might be or any further information that I might provide that could help. I would also appreciate any instructions on how I can fix it. Thanks everyone!
Sincerely,
John Yossarian
Based on what I am seeing this television is a tube type correct ?
If so, it could very well be a convenience issue which may have to be repaired by a pro.
Does this issue happen on all inputs ??
Plain ole user
Have you determined which sources it does it with?
It happens with at least both the Component and Composite inputs. I haven't been able to try any of the others.
This is a CRT (tube) type of RPTV. Did you mean to say that it could be a convergence issue?
Plain ole user
Most likely. Having simultaneous problems is unlikely. I would be looking for where the signals are missing in the A & V paths and then see what is common to both. That kind of troubleshooting requires a schematic and possibly a scope. The most likely thing for both A & V to have in common is a signal switching circuit or power supply.
