1 - 18 of 18 Posts
as the title says, im looking for a way to get my in ceiling surround speakers to sound better and i wondered if anybody knew of any universal type enclosures i could put up in my ceiling to make them sound better. or could i just cut a strip of some insulation and throw it over top of them, i dont know?
I'll bet those would do the trick if some dampining material was added to them so they sound solid, good find.:T
Never thought about the bucket idea. Would they resonate, even with damping material? A simple MDF box would work also, but the one at PE is not too expensive and made of steel. Nice to have options.
If it were me and using any of the ideas i would use some sort of Dynamat type material that should tame crazy sounds the enclosure might add. The MDF box i would leave be as it probly won't effect the sound like using metal or plastic may.:T
^^^ Agreed! I use Dynamat on all our cars (doors, floorboard, trunk bottom-lid-sides, etc.), really helps a lot with metal surfaces. Great material!!!
So a question on the bucket, how do you seal it since there are no flanges to screw down? Do you just use silicon caulking (that can create a pretty strong bond, but I wonder how it will hold with the extreme temperature changes that can occur in some attics - I know that our attic here in Albuquerque will hit over 150F in the summer and below freezing in the winter).
I'll have to keep the bucket idea in mind for future installs, seems like a great idea.
Discussion Starter · #14 ·
well the metal ones from PE i think will do me fine, i didnt think about the dynomat so ill probably get some of that as well. i cant use a bucket (5gal) because of space issues. does the dynomat reflect sound or absorb it or what? reduce vibrations? im asking because the speakers are approx 10-15 ft away from my furnace and im hoping to reduce/remove any of that noise from getting into my speakers. ive got a hard ceiling in my basement and ive got lots of "noise" bouncing around where all that space is between the floor joists.
Dynamat will reduce resonances and deaden the enclosure and should also tame any sounds from entering or exiting the enclosure.
1 - 18 of 18 Posts
