1 - 8 of 8 Posts
G
I just picked up some new Paradigms.The new V5 Monitors. A pair of Titans,CC-290,and a pair of Mini Monitors that I am going to use for surrounds. I am payiently waiting for my new Onkyo TX-SR605. I just picked up some 14g speaker wire. I am now looking to buy some banana plugs. Whats everyone using? Where should I order from? Regular or locking? Thanks for the help. John
Ryan, those look like some solid plugs. I bought a 4-pack of really ****** Acoustic Research plugs at best buy for ~ $9. I think I may have to invest in some of those. Thanks!
I actually like those ****** AR plugs from best buy! I had the GLS black chrome plugs for awhile, and even though they are nice looking they were just too big, heavy and bulky for my tastes. The AR's are some of the only ones that fit in my binding posts without sticking out.
I've also had good luck with some Dayton plugs from parts express.
Yeah, the AR's will definitely work if you have smaller cable, I just don't remember if they would accept 12g wire. Also, the plugs on the AR's seem much shorter than any of the other plugs I saw there. However, they are snug! I can definitely see how those GLS plugs could be a little bulky. Just don't go out and spend $20 for two pair.
1 - 8 of 8 Posts
