1 - 5 of 5 Posts
Hello
I appeal to you because I do not know which central speaker to choose between these two models:
Klipsh RP-404C
Klipsh RP-500C
Their characteristics are quite close.
I doubt that the model with 4 speakers should be better but is the difference really significant for a room of 22 square meters?
Thank you
HTS Moderator , Reviewer
Because your room is not very large a wide center like the RP-404C might not be the best option. The RP-500C may be a better choice and should provide all the output and detail you would need.
1 - 5 of 5 Posts
