OK, so i spent about a month setting up what i have currently, and overall i'm satisfied, but i'm already curious about a few things. Let me describe my setup.
I have my PC Connected to an equalizer, connected to a stereo receiver with no sub-out. The equalizer has multiple outputs, so- i have the equalizer going to a Sampson s-convert, then dual XLR cables going to a behringer dcx2496, and a single XLR going out to the input of a Behringer epx2000.
the (both) advantage and disadvantage of this setup is: i have independent control of the subwoofer from the rest of my speakers.
there are a few things i am wondering about
a) should i use a line-out converter on my speaker B outputs to feed into the sampson s-convert? my receiver is only 75wpc- I think most LOC can handle this with ease.
b) would it affect the sound quality? i'm sure my receiver and my sound card color the signals quite a bit differently.
c) should i drop this setup and go for the rythmik f12se? i currently have a dayton hss315hf-4 being hit with 650watts from the behringer (maybe a bit too much)
i would appreciate if you could help me answer any of those questions - the other thread i made got 0 responses so maybe i am not being very clear, i'll answer any questions you have. thanks!
