1 - 4 of 4 Posts
I have a set of Linn Nexus Speakers that have tube connectors on the back. I set for the woofer and 1 set for the tweeter. I had been bi-wiring but want to go with a single wire then use jumpers to connect the tweeters. The input terminals do not have any nuts or hardware attached of any kind. I have searched for a adapter to make this connection without any luck.
Does anyone have suggestions on how to do this while retaining as much connectivity as possible?
Thanks in advance.
Thanks Wayne. I do not have any nuts on the back of my speakers to hold down bare wire. There are barely any threads coming through to hold any nuts. My bananas work fine. But I need to find a way to split the cable from the amp into 2 feeds without using the entire length of wire. I would like to use jumpers if I can find the right adapter.
1 - 4 of 4 Posts
