21 - 39 of 39 Posts
Discussion Starter #21
Ok so the cables that are available are Monster cables
1) Monster XPCIBIG - costs around 106$ for 30 Meters
2) Monster XPN WMS100 - costs around 80$ for 30 Meters.
Are expensive cables necessarily better or is the second option enough ?
I might be making my purchase today.
I am still amazed with spending all that money on a receiver, and then
looking at the lower budget friendly speakers and subs.
Since the deal is done I was not going to say anything about this, but it agree completely.
Stanjohn,
When it comes to wires and cables (especially speaker wires) cheaper is better because the cheap ones work just as good as the expensive ones.
The only thing spending more money does is perhaps get you a better looking cable.
Discussion Starter #23
Stanjohn,
Thanks. I'll go with the cheaper Monster Cable.
I wouldn't even buy a monster cable at all. When buying monster your paying for looks and the name. Sort of like Bose systems. Save your money.
I used to live in the Middle East, and have been to Kuwait. I feel your struggle. Finding certain things and companies to ship to you is a pain. Good luck to you and the building of your system.
Discussion Starter #27
Thanks. Do you know if Marantz SR6008 will power Polk Audio RTi A7's without issues ?.
Some guy's at the Polkaudio forums said that no receivers can power the RTi A7 without external amplification at higher volumes and there are chances that I could ruin the speakers by under powering it.
Your receiver will be able to power them without damaging the speakers.. Polks have high sensitivity and are easily driven. Now don't expect ear bleeding levels without distortion and your amp clipping, which you want to stray away from because you will fry those dome tweeters in no time.
Discussion Starter #29
Your receiver will be able to power them without damaging the speakers.. Polks have high sensitivity and are easily driven. Now don't expect ear bleeding levels without distortion and your amp clipping, which you want to start away from because you will fry those dome tweeters in no time.
Thanks a lot for the info. I doubt I will go above 60% with the volume ever. Might baby it a lot.
Don't get me wrong, you will be able to play loud. Real loud. It's just when you start to push limits will you strain your receiver. You will be fine without external amplification. If any reason to go that route it would be more for improving the life of your receiver than sound quality.
Per Polk the RT1 A7 is
Total Frequency Response 20Hz-27kHz
Upper -3dB Limit 26 kHz
Lower -3dB Limit 35 Hz
Nominal Impedance 8 ohms
Efficiency 89 dB
The Marantz will own those speakers.
Play it as loud as you want.
When your ears start to bleed turn it down a couple of clicks or turn it up a couple more depending on your mood.
Discussion Starter #32
Guy's I've finally purchased it :). Will be receiving it in 2 days. Excited !
This is my setup as below
Marantz SR6008 Receiver
RTi A5 , A1 , Csi A4 and DSW Pro 660 Wi Speakers.
The reason I didn't go with the A7 is that they had only 1 display piece which was slightly damaged and it would take a few months for them to get the new stock.
I heard the Andrew Jones Pioneer , they were good upto mid level volumes but once you increase above that it wasn't good.
The JBL Studio 1 series were good even with the relatively tiny subwoofer , they were really loud and slightly harsh.
The Polk Audio RTi's , just loved them :) mild and exactly right , the way I like it.
Also for speaker wires I couldn't find anything cheaper than a monster cable so had to go with it , but the good thing was I got it for free :)
As for the subwoofer cable I have gone for something cheaper ( EQ 31 AC non-branded ) hope it doesn't affect quality.
I personally thank each and every one of you for your invaluable advise on this thread which has helped me immensely in making the right decision.
Really I owe you guy's a lot ,since you all made me sway around from purchasing a high end HTIB to a component system. If it wasn't for you all I may have just bought an expensive / overpriced HTIB.
Will be starting another thread soon so that you all can help me tune my system to make it sound perfect.
Love this forum and all you guy's. Thanks :)
Glad that you made a decision.
Hi, From where did you pick the RTi A5 , A1 , Csi A4 and DSW Pro 660 Wi Speakers in Kuwait. I am also actually looking out to set up a 5.1. Your feedback would be appreciated.
21 - 39 of 39 Posts
