so I should eq flat and play 31hz and a 80hz signwave so they sound the same @ 115db to get the house curve target. Then re-eq from scratch with the house curve applyed. Because I would probably not need to eq a aggressivly in the higher hz range?
If the goal is 115db should my house curve be approx 35db (115 - 80 = 35). If of couse you watch movies @ 80db
