G
Guest
·We purchased our Samsung HLR5067 WAX 50” TV about 2.5 years ago. A few months ago, we were watching TV for about 1-2 hrs and all of a sudden a semi-transparent gray bar appeared on the screen; it was probably about 3-4 inches in height and went across the whole width of the TV. The gray bar remained on the screen no matter which mode we change it to. As soon as it happens, we turn the TV off for a few hours, and it usually goes away. This has been happening about every 1-2 weeks now. The gray bar is usually on the top part of the screen, but sometimes it appears in the middle or bottom. Also, while we're watching TV the sound intermittently goes out for a few seconds, and then comes back as if nothing is wrong...
Is anyone else having this problem? Is there an easy fix? Help!
Also, when do we need to replace our Bulb and color wheel?
Any helpful hints would be greatly appreciated!!!
