1 - 5 of 5 Posts
Well, I just purchased this used Toshiba 52HMX95 DLP projection TV set and while I love the size, when viewing a bright scene, there is a slight fuzziness to the picture. Kind of like a glow to the white/bright area. Any input on how to fix this?
Can you get a picture of it? Offhand I'd recommend adjusting your Black and White levels with either a calibration dvd or with the THX optimizer found on several movie dvds. Maybe your brightness is set too high.
Plain ole user
Clean the optics.
Discussion Starter #4
OK, I can't get a good picture of it. In general, the white haze seems to be bleed off of the white lettering. I've tried playing with the settings to no avail. Any other ideas?
Discussion Starter #5
Clean the optics.
How exactly does one do this? THis set was in a bar before I purchased it and the outside did have a not of smoke grime on it. I'm guessing the same stuff is inside the set and on the screen. Advice on how to clean the screen/optics would be greatly appreciated.
1 - 5 of 5 Posts
