Hey guys,
I planned on upgrading my HT setup and have had my heart set on Kplisch speakers all the way around along with a Denon Receiver. My current receiver is one that I bought a couple of years ago; the AVR-791, which I really enjoy, but don't get to hear the great audio that this receiver can dish out because of the Panasonic Speakers. My current Subwoofer is actually my nicest speaker I have and it's a Pioneer SW-8 8" Ported Subwoofer. During that time, I read up on alot and did an insane amount of research.
Well that was a few years ago and I have lost most of my knowledge. Things happened between then and now. I'm selling it all off and starting from scratch. I was originally going to go with my pair of TC Sounds TC1000 12's with the TC2+ Motor. But I don't have those any longer, sooo
I just bought a TC Sounds TC9 12" Subwoofer. I have read there are so many variations of this and other TC Sounds subs, but I think it has to do with the motor, not the actual subwoofer. I know car audio VERY well. It's one of the few things I am very knowledgeable about and that I am very good at. HT is a completely different area.
The HT setup will be going in a living room with carpet. It will be moved around from time to time into different living rooms, till I get my first house and by then, I'll have an entirely new setup. I want my subwoofer to really rumble down low. I also want you to feel the bass that will make my friends to have their jaws dropped. I was thinking around the 18-20Hz range? I have no idea assuming the lowest someone would build their box design to a frequency of 14Hz and as high as 30Hz for HT usage. There will be minimal amount of music only being played. The occasional party will have music playing, but it's not likely that the stereo will be so loud to have a consideration for my frequency tuning; so this frequency tuning of the box design will be for 100% HT only.
The Specs of the TC9 12" Subwoofer are below the bottom.
What I need to know is the following..
1. I need a good budget friendly amplifier. This sub, unfortunately, is a Dual 4 ohm sub, so I have to wire it for a 2 ohm load or an 8 ohm load. No 4 ohm loads here. I want to be able to throw all of the wattage at it that it can handle, which is up to 1kwrms
2. I need an opinion on the NET size of the box. What is recommended for a ported box, which I believe is for car audio, is: 2.0-2.5 cubic feet.
3. I need to know what I need to have the tuning of my box to be.
Features:
-Single piece aircraft aluminum cone
-Dual 4 ohm voice coils
-140oz large diameter motor for awesome motor strength
- Anti-flux-modulation shorting ring to reduce distortion
-High temperature low eddy-current stainless steel voice coil former
-Full 1" symmetrical XBR surround for over 2" peak-to-peak excursion
Thanks!
Specs:
RMS Wattage- ~800w (Can 600wrms-1000wrms)
Fs - 26.5hz
Cms - 187.8 um/N
Mms - 192.1 g
Qts - .321
Qes - .341
Qms - 5.562
Re - 3.156
BL - 17.2 T*m
Sd - 78.54 sq.in.
Sens - 87.71 1w/1m
Mounting Depth: 6.2"
Diameter: 12.6"
Cutout: 11.1"
Weight 23.8 lb
Features:
Thanks!
Specs:
Fs - 26.5hz
Cms - 187.8 um/N
Mms - 192.1 g
Qts - .321
Qes - .341
Qms - 5.562
Re - 3.156
BL - 17.2 T*m
Sd - 78.54 sq.in.
Sens - 87.71 1w/1m
Diameter: 12.6"
Cutout: 11.1"
Weight 23.8 lb
