I've got a Sanyo Z700 that used to be set up with a 96" Black Widow screen. The basement got flooded last spring and I had to take it all out. After some basement remodeling I'm finally ready to put it all back together. I was hoping you guys could help me figure out the best diy paint mix to use. Here's my info:
Projecter - Sanyo Z700 - known to need help with contrast
ANSI Lumens - 1200
Calibrated Lumens - About 650
Distance to Screen - 9 feet
Screen Size - 92" 16:9
Seating Distance from screen - 10 feet
The ceiling is only 80 inches from the floor and the screen wall is only 108 inches wide. I'm concerned about light reflecting back on the screen since the side walls are only 18 inches away from the screen edges. The ceiling is flat back (painted that while the wife was at work), the walls are a matte peachy biege color, and the floor is a biege carpet tile.
I rolled the Black Widow screen that I made before, but I now own a Wagner Double Duty HVLP that I would like to use to spray the new screen.
Thanks in advance for any info.
ANSI Lumens - 1200
