1 - 3 of 3 Posts
I have a panasonic LCD model # PT50LC14 television. A message has come up telling me to clean the air filter has anyone had this problem and do you have a solution. Thank you.
Welcome to the Shack, As the message is telling you there is a filter located in the rear of the display, I don't know your set personally however looking at the information I have found it is located right beside the bulb and requires you to remove the back of the set and is not a quick job.
I realize this is an old thread... (Well, I realized it after looking at the manual).. but I thought this was interesting:
Manual here:
http://service.us.panasonic.com/OPERMANPDF/PT43LC14.PDF
Manual says to consult dealer if you get the Air Filter Cleaning message.
Hopefully it's still a quick thing to clean... but who knows, it might not be if it says consult dealer!
You'd think that an air filter is simple to clean.
1 - 3 of 3 Posts
