1 - 2 of 2 Posts
hi everyone.... im looking for home theatre setup of 5.1.2 atmos setup for a room size 21 ft L x13 ft W.
I’m totally new to this area and would like to do a setup as soon as possible. can someone pls share your views whether the below setup will be the compatible or I can replace some speakers to get better performance.
1. Denon AVR-S730H – 7.2
• Power Output (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive) – 80W
• Power Output (6 ohm, 1 kHz, 0.7% 2ch Drive) – 120 W
• Power Output (6 ohm, 1 kHz, 10% 1ch Drive) – 175 W
2. Infinity Harman REFERENCE 263 - Floorstanding loudspeaker, 3way dual 6.5inch, Frequency response-38Hz-22KHz,sensitivity-89db,nominal impedence-8ohms
3. Klipsch Reference R-25C Center Channel
4. Klipsch R-3650-W II In-Wall Speaker
5. Polk Audio MC80
6. Polk Audio PSW125, Active Sub-Woofer 12" Inch, 300w Front Firing - Black Color
1 - 2 of 2 Posts
