Good day
I want to build 2 X 12 inch sub for my home theatre preferably sealed . What would be your recommendation in term of driver and size of box
Thank you
Good day
Thank you
Budget? SPL and extension goals? Size of box is more to do with the specific driver....
budget between $350 and $800
spl and extension have not thought of it not sure what is standard
We also need to know what you are listening to?
Is it 10% music 90% Movies or the other way around? And what mains/receiver do you have.
Hi
listening is 70% movies 25% videogames and 5% music
my main receiver is an Anthem MRX300 but the sub will be powered by 2 X Behringer EP4000 that i have and minidsp 2X4 balanced
guess what i would like to achieve is clean deep tight bass
Thanks for your help
Is there a particular reason to limit the driver to 12 inches? How large is your room (is the room sealed or open to other space?).
Believe the Stereo Integrity HST-12 would be a good choice and is just in your budget in any case.
