Hello HTS!
I recently moved to Florida and gave up my basement theater that I had in Kentcuky. Tired of seeing the projector setting in it's box I decided to put it up in my non-light controlled, limited projector placement having family room.
I'm looking for some help in determining/designing a DIY screen frame. The screen will sit directly in front of the TV when in use. I've been brainstorming of some type of rollup/foldup removable screen or a fold down frame that sits above the tv when closed and stretches the screen material as it's unfolded. With this being said, I have limited experience with DIY screens (my last screen was stretched canvas on a wood frame primed flat white), I don't know if paint will crack if rolled/folded, and God knows what else i don't konw i'm ignorant about.
If anyone can give me some tips/ideas/whatever I would be very appreciative.
What I have;
Optoma HD70
125" 16:9 Screen (bigger then i'm happy with for the projector, as small as I can zoom)
I'll need 6" of clearance from the wall to clear the TV.
Thanks !
This is where the location:
What I have;
Optoma HD70
Thanks !
