1 - 5 of 5 Posts
G
I am planning to replace my old HT setup to high end setup. I am considering either an Onkyo TX sr 706 or Denon AVR 2309 for the receiver.Speakers will all be paradigm. Front speakers Monitor 11....Center Adp 390....Surround CC390...Subwoofer Ultra cube 12 dsp series.
I would like to know if these set of equiptmnet will be considered as high end already for a home theater setup. will the speakers compatible with the receiver and what do I expect when listening to music and watching movies.
Kindly give some comments and advice.
The Onkyo 706 would not be considered "high end" your only getting into high end receivers when you start getting into the $1000+ receivers but non the less it is a very capable unit. If you can squeeze a little more the Onkyo 805 is a much better receiver.
Again Paradigm makes good speakers but not what most would call "high end" for most systems the ones you list will do just fine . How large is your theater room?
G
Thank you very much for your comments and advice. Im very glad to be here asking question, now I am learning about HT. Ok I am going for onkyo 805. My theater room is 15x25 feet.
Thats a good sized room, the 805 is a good choice. Your speakers should do fine in that room.
1 - 5 of 5 Posts
