I posted here prior (http://www.hometheatershack.com/for...-building-dayton-15-classic-4-ohm-sealed.html)
As the title of this post says, I will pay $10 paypal for the sub plans for this particular driver. I would like to build the box out of plywood rather than mdf for cost and weight savings and I will probably reinforce it of course.
I am thinking a slot port. Driver is a 15" Dayton Classic 4 ohm. Amplifier is a Parts Express Dayton 240 Watt Plate with 6db Bass Boost at 30 hz.
Specifications:
Subwoofer
Power handling: 250 watts RMS/350 watts max *VCdia: 2" *Le: 2.30 mH *Impedance: 4 ohms *Re: 3.1 ohms *Frequency range: 20-500 Hz *Fs: 20 Hz *SPL: 92 dB 2.83V/1m *Vas: 9.70 cu. ft. *Qms: 4.00 *Qes: .50 *Qts: .44 *Xmax: 8.5 mm *Dimensions: A: 15", B: 14", C: 6-3/8".
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-470
Amplifier: Dimensions: 9-13/16" W x 9-13/16" H x 5" D. Cutout dimensions: 8-1/2" W x 8-1/2" H.
* Power output: 170 watts RMS @ 8 ohms 240 watts RMS @ 4 ohms
* Bass Boost 6dB @ 30Hz
* S/N ratio: 90 dB (A-weighted)
* High power/low distortion
* Adjustable low pass crossover
* Auto On/Off
* Phase reversal switch
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-805
I would like to build a slot port but beyond that I am not sure. I would prefer it to be 4 cubic feet or so. Additionally there must be room for the amplifier inside of course.
Specifications:
Subwoofer
* Auto On/Off
