We are closing on our new house in Mexico on Friday. Our living room will become our new Home Theater/Stereo (No dedicated room this time). The room is 19' wide with a 30' boveda ceiling, and is approximately 20' from the loft to the windows/doors. The distance from the bar to the windows is 30'. We plan on mounting a projector to the ceiling of the loft floor, and have the screen come down in front of light blocking curtains installed over the windows. The entrances to the wine cellar, and upstairs will be blocked off with sliding barn doors. The walls are about 1' thick clay brick, and the ceiling is also brick with the floors being Cantera black marble. This is def a live room that will be a challenge to tune.
I am starting this setup virtually from scratch, and it will be taking a while to get it back up and running again.
Equipment I have:
Yamaha cxa5100
14 channel DIY amp...to be disassembled, and amps to be either installed inside of biamped speakers or next to them (along with minidsp 2x4 crossovers). Amps will be plugged into Insteon outlets, and individually turned on and off according to how many channels are required.
JBL surround speakers from my old setup will be used for Atmos channels. Klipsch k402 speaker will be converted to a 2 way Synergy style speaker, and then I will make more to have a 5 channel setup utilizing my old EV DH1A drivers.
195" SeymourAV screen (new frame will have to be made, as I used the old frame to make our new equipment racks
)the screen will lower down in front of the speakers. I am trying to figure out the sliding rails for each side of the screen, and a way to motorized the screen lowering, and raising from the area between the 2 windows.
Project RPM 1.3 Carbon turntable with Sumiko cartridge
OPPO 203
Furman power strips
Monoprice 75' XLR cables for the front 3 channels
Pioneer bluray player for ripping movies to our Unraid NAS
T channel audio rack with sand bed shelves. I will be modifying the config for the new setup, and making it about 6' wide, but lowering it to counter level.
Either coming or planning on getting: (no particular order)
1: $600 worth of Roxul for sound panels on order
2: 4k projector ?
3: Linear slide rails for moving the screen into position, and some sort of motor assembly controlled via Insteon
4: Dirac ?
5: Sub?
6: Bass shakers?
I am sure there will be more additions. Question marks mean brands, and models unknown at this time.
Sent from my SM-T550 using Tapatalk
Equipment I have:
Yamaha cxa5100
OPPO 203
Furman power strips
2: 4k projector ?
4: Dirac ?
5: Sub?
6: Bass shakers?
