Recently moved to a new home, I'm setting up the room of my audio system. It's not a "normal room", as you can see; I bought UMIK-1 mic and studied REW but everything is new therefore I need a little big help :-(
Loudspeakers: from side wall 65 cm., from back wall (tube traps) 170 cm., from listener and between loudspeakers 220 cm.
I experimented a number of different solutions, the following I think is .... the best one. There are two peaks at 45 and 100Hz, an attenuation at 300Hz. What is your opinion about this plot? Do you need other plots? any suggestions?
Tks
Tks
