Hi everyone, hopefully somebody helps me with this problem
I have one Samsung HLP5085W, with the same problem:
No picture but sound works.
I replaced the bulb and still does not work. I checked all the connections: color wheel, ballast and switch door and everything looks great except that there is a crack in the square glass cover in front of the color wheel. I just want to know, which is the wrong piece the ballast (I measured the voltage and the result it's about 320 volts) or the color wheel?
Note. I followed the sound test to discovered the problem and apparently the error is on the step number 3 (1] Fans Start 2] Tone Up 3] Color Wheel Starts 4] Lamp Lights 5] You get picture and sound) And I do not hear the Color Wheel spinning up, if the color wheel does not spin the ballast does not fire? I manually checked the color wheel and it freely spins, all the crystals are in good shape.
I really appreciate any help to buy the correct piece.
