I am looking to get a better subwoofer for my room. I have a Insignia 600 watt Receiver, and front and surround speakers. The fronts and others are pretty cheap, but they are actually really clear and have taken quite the abuse. I also have a Yamaha 10" YST-SW216 100 watt sub and I'm not pleased with the performance of it. It is alright, but tends to bottom-out quite a bit when listening to demanding songs. My room is 13x13.
What I am looking to do is: get a amplifier like the Pyle PT3300 for the Sub or Subs ONLY by using the RCA outputs on the back of it. It's found on ebay, but the thread won't allow me to post the link.
I was also thinking about 2 Kicker COMP C10's, or one Diaond Audio D3 10". But then I ran across a RE Audio SE 10" sub also. Which of these subs would provide the best SQ or SPL? I want the sub to be able to handle the lows in songs, like Down 4 Tha Krown by Kottonmouth Kings. I would also prefer SQ over SPL, but would like to be able to have alot of SPL if needed. I was suggested one Dayton DC300-8 12" Classic Woofer, one Dayton DC380-8 15" Classic Woofer, or two Dayton DC250-8 10" Classic Woofer off of Parts Express. Which of these should I go with, if any? I have about a price limit of about $140 for the sub only, and around $150 for the amp.
Any help on deciding on what subs to get?
Thanks in advance.
Edit: I was also suggested a Dayton SA240 240 Watt amplifier off of Parts Exppress also. Is this a good amp, or is there something that has more output for cheaper or under $150?
Thanks again
Thanks in advance.
Thanks again
