:help:hi, i have a gale 3090w sub and i have just purchased a 12" 500w sub, i want to know if it is possible to place this new sub in the gales 3090w enclosure ?..
That will depend what 12" 500w sub you purchased. The driver needs to work in the Gale's net volume which is about 1.5 cu.ft. What is the make and model number of the sub you bought?
I can't find any T/S parameters for the sub to model it. All you can do is try it and see. Assuming the amp on the Gale is 4 ohm, you'll have to wire the sub in series for a 8 ohm load.
