New to REW, Input signal to low...
3507 Views 3 Replies 3 Participants Last post by  niklasmagnus
Hi, I am new to using REW and am having trouble setting it up.
My Equipment is as follows:
Behringer ECM8000 (Microphone)
Behringer U-PHORIA UM2 (Phantom Power Sound Card)
Behringer iNuke 1000DSP (Subwoofer Amplifier)
Audioengine A5+ (Bookshelf Speakers)
Audioengine D1 (24bit DAC)
Polk MM1240 12" (Subwoofer in sealed box - only temporary)
Windows 7 64bit computer (Source)
My issue is that when I "check levels" the input signal is always to low, even with the input gain on the UM2 at maximum. The gain on minimum yields about -48 dB and at maximum yields about -43 dB.
Any help with this is much appreciated,
Thanks.
1 - 4 of 4 Posts
Surprisingly small range of change for the mic gain adjustment. Phantom power definitely turned on? How is the REW soundcard preferences page set up, can you post a screenshot of that?
Wow, I'm such a noob at this :blink:, the phantom power switch was turned off on the back of the UM2...
Thanks for the help.
Hi Zhigre,
Did you get the loop feedback "Timing reference input/output" to work with the Behringer UM2. I'm thinking of buying one of these but not sure if it will do the job?
BR
Niklas
1 - 4 of 4 Posts
