21 - 33 of 33 Posts
Discussion Starter · #21 ·
Wow. That was more than a quick pointer. Thanks for the visual aids. I definitely had an issue with the measuring tool. The plot below has the meter about 2" from the sub's cone. IMO it shows the subwoofer performing as it should. However my room needs some help. The big 60 Hz dip has something to do with the bay window. Only when the mic was not in front of it or the sub more to the side did it go away. I'd like to thank everyone again for all your help. REW is a great tool!
Text Line Green Pattern Pink
Discussion Starter · #23 ·
You might try some outdoor measurements just to see what this looks like so that you can identify it in your room.
I missed winning an external USB sound card on Ebay by $1.00!! I need to get one soon for some outdoor testing. Also I'm considering an upgrade on measuring equipment. The RS meter is apparently only accurate down to 24 Hz.
Mike, if I get a good outdoor measurement, can I then compare it to the room measurement and draw some conclusions on what the sub is doing vs. the room modes? I've also learned that my Bash 300 has a 1 dB boost at around 28 Hz. This apparently is also a high pass filter at 17.7 Hz. It can be changed by replacing a few resistors. I assume this will change the response vs. WinISD as well. Do you guys ever send a high level signal to the sub to bypass the amp for comparison purposes? Below is my latest measurement with the SPL meter properly set and the sub in a better location (no more 60 Hz dip).
Blue Text Line Plot Diagram
It's not particularly accurate in general, but it's fine for home use and can be used down to 10Hz with our calibration files - You are using a calibration file?
Certainly.
Discussion Starter · #25 ·
I am using the calibration file.
One other question. The plot in post #21 was taken with the meter about 2" from the cone. Does this method minimize room gain? I'm asking because f3 is at about 25 Hz. Much lower frequency than predicted by WinISD. I need to measure this thing outside!
· Super Moderator
Sorry, my response was admittedly a bit hair-triggered. Sure, close-micing will get you a different response reading than what you'd get at the listening position, but it's not going to totally eliminate the effect of the room. This will be obviously apparent once he performs his outside measurements.
The only exception would be a quick gated reading. I seem to recall some discussion as to whether or not REW could do this, but I don't recall the details...
For sub testing, you don't want to alter the IR gating, since the gating puts a limit on the lowest frequency and the resolution of the response. For example, if you were trying to limit reflections from surfaces 1 meter away, you would use a 6msec gate (d=(time*speed)/2), but this would limit the lowest frequency of usable response information to ~167Hz (1/gate time). Not much use in this case. The default windows are much better for low frequency testing. Gating is reserved for measuring mains.
Moving a sub to the middle of the room and taking a near-field response is a pretty good method of removing the room. One of the problems that arises is that it isn't very practical with a ported sub, since both the driver and port contribute at different frequencies, and so setting the mic to get a decent mixing point places you outside of the area you would consider near-field. In that case it's better to drag it outside.
· Super Moderator
I had forgotten about the graph Brian showed us in post #21, which pretty well supports your contention; I can’t imagine an outside measurement showing anything different other than less extension (which would be from a lack of room gain). Sorry to sidetrack the thread. :(
Well you're getting proximity gain on the microphone by putting it right up next to the cone (in other words, changing the frequency response of the mic). I dunno how big of a deal it is with the ratshack meters. You'll also be getting some effects of room gain as well. Really, the only way to know is to do some outdoor measurements ;)
Btw, the WinISD predictions are very accurate in terms of power response in half-space (middle of a field). Sometimes the shape of the cabinet and the arrangement of the driver(s) can affect the on-axis frequency response. Adding other boundaries (like putting the sub into a corner) will change the on-axis frequency response too. But in all these cases, the power response is essentially the same....you're just redirecting where it goes (and hopefully keeping it in phase).
If your subwoofer is "small" (relative to the wavelengths), then the polar response will be nearly omnidirectional - in which case, the power response and on-axis frequency response will have the same shape.
All that to say, you can take your WinISD prediction and then find a transfer function that matches your in-room measurement. I should confirm this before mentioning it, but room gain is typically about 12dB/octave, but looks more like a shelf filter because eventually the walls start getting more transparent as you go lower in frequency. But knowing the shape that room gain should be helps you in determining the transfer function that matches the difference between your measurement and the WinISD model. When you get it right, this transfer function can be applied to alternate designs and yield predictable results.
The nice thing about sealed cabinets is they also roll off at 12dB/octave....so if you can find a driver that has an F3 with a Q of 0.707 where your room gain kicks in, then you should expect to measure a frequency response that extends down to DC - but it'll roll off earlier at the point where the room starts getting more leaky.
That said, I disagree with the notion that "flat after room gain" is the goal, but that's getting into the realm of psychoacoustics instead of the realm of understanding why things measure the way they do. Knowing why things behave the way they do makes it possible to design for a target dictated by psychoacoustics. Anyways, I might suggest that we can perceive room gain without there being any music playing and therefore we establish our perceived "zero" as starting with the room's natural "frequency response". My current position is to be flat after boundary gain, but before room gain...which is kinda hard to quantify without getting extreme with the measurements. I've actually come across a recent article that talks along those lines too...I wonder where I put that one.
Discussion Starter · #32 ·
Mike, your forcing me to learn about aspects of this hobby that are clearly more than just a hobby to many people in this forum. It's great! I'm a mechanical engineer, I enjoy learning about this stuff.
I had to read the first half of your post a few times, but the second half I understood. Transfer functions make sense to me and your explanation of
makes perfect sense. Do you tune the simulation with equalization to represent the room's response?
Also so can you explain the difference between boundary gain and room gain? Thanks.
I'm an electrical engineer myself and usually try to suppress the engineering topics because it ends up being more involved than people usually want to get (nothing wrong with that either)...so I enjoy an opportunity to talk engineering speak :)
Not sure what you're referring to here???
Here's how I understand it:
Measure the subwoofer in the middle of a field - this will be half-space. Now measure the subwoofer sitting beside a really big building (basically a big wall in the middle of a field). This gets you a 1/4 space measurement and ideally you'll see +3dB at every frequency relative to the 1/2 space measurement. Then measure with a big corner out in the middle of a field....so a 1/8 space measurement. You'll ideally see +3dB at every frequency compared to the 1/4 space or +6dB from the 1/2 space.
What's happening is the energy that would normally be travelling rearward is reflecting off the wall and being redirected forward. Therefore, the intensity (amount of energy per area) increases in front of the speaker. The intensity at a single point in space is what is being shown in a normal frequency response plot. If you integrate the intensity over all space, then you end up with the power response (the total energy being delivered by the speaker at each frequency).
The +3dB from halving the space the driver is firing into is true when you assume that the speaker has an omnidirectional polar pattern and that the reflections take zero time to occur. So the only time this is true is for a point source located on the vertex of the boundaries.
In the real world, the driver has a physical size and the cabinet requires that the driver sit away from the boundaries. This prevents the existence of a perfectly omni-directional polar pattern and the reflections are delayed by a small amount. This seems pretty simple, but I've always been surprised by just how different an outdoor 1/8 space looks from an outdoor 1/2 space measurement. I wish I had some electronic copies to share as it is really quite surprising. Anyways, the point is that the difference in behavior is not at all trivial (we're talking like +-3dB at least).
When you put the sub in the corner of your room, you're always going to see the same 1/8 space behavior, but it gets a bit more complicated because you have a ceiling, and extra walls to deal with. Some of the reflection paths will be long, and some of the reflection paths will be short. When they're short, our ears perceive it as part of the direct sound and so we hear the dips/peaks that it introduces. When they're long, our ears perceive it as part of the natural sound of the room - so the dips/peaks aren't necessarily perceived.
So is the ceiling a part of the boundary or room response? Well I think it will depend on the frequency in question. I think the real question should be, "is the delay long enough to be perceived as part of the natural sound of the room, or is the delay short enough to be perceived as part of the direct sound from the driver?" I think answering that question in context of a specific situation should likely reveal the best path to a solution.
And then another behavior to throw out there...
When you have reflections in the room, there is a good chance that many of those reflections will find their way back to the driver itself. Increasing the air pressure in front of the driver will improve the coupling of the driver. Likewise, decreasing the pressure in front of the driver will reduce its coupling. Horns basically work on the principal of providing more pressure in front of the driver so that more power gets transferred. In fact, it is this behavior that creates the 12dB/octave room gain that we observe - basically, the wavelengths are long enough such that the reflections are in phase with the driver - thereby increasing the amplitude in front of the driver and increasing its coupling. As you go lower, you get more and more in phase (since the phase rotates slower and the time of the reflections are fixed). Things can get real complicated real fast when you consider all the reflection paths that might improve or reduce the coupling of the driver. So in a case of a horn, I'd call those "reflections" as happening early and therefore being perceived as part of the direct sound. In the case of the 12dB/octave room gain of the room, that behavior is going to be delayed by quite a bit since the sound has gotta slosh around the room for a bit to capture the full effect. We also naturally hear the power response of the room with no music playing either, which just reinforces our perception of it being more of a "reverb" than a "direct sound".
All that said, I don't think there is any way to easily determine what would constitute an ideal target response for a given measurement in a particular location. I might suggest that it's easier to think of it in terms of "boundary gain" vs "room gain", but in reality it's going to be a continuum of both - and the fact that it is a continuum makes it real hard to draw lines. But really, it may not be necessary since there is only so much we can, or are willing, to do....in which case it is important to be aware of how we perceive the sound so that we don't make unintentional sacrifices.
21 - 33 of 33 Posts
