1 - 20 of 35 Posts
Hi all, as stated above I'm new to this site but LOVE all the information on here. I also would like to confess that I know very little about the AV world so to speak.
I am looking to pass some wires so I can get Pay TV put in my Trophy Room and while passing these cables I am going to also pass extra cables so I can run a projector in this room also in the near future as its a massive job passing cable in a room like this as it has a Cathedral ceiling and because it is a tin roof means the cavity is very narrow only 125 mm or 5 inches.
Just to give you a better understanding about my Trophy Room. The room is quite large 14 meters by 10 meters or 46 feet by 33 feet. The walls are 13 feet high and the center of the cathedral ceiling is approximately 20 feet high. Unfortunately I totally understand that this room has a lot of flaws going for it, acoustically speaking but I basically live in here especially during winter as I rarely go out due to my disability being a Quadriplegic I really feel the cold and HATE it.
I have tried to attach a couple of photo's of my trophy room but doubt it will work because this is my first post. I hope the photo's work to give you a better idea of what I am trying to explain about my room, but I think I cannot post photos until I post a minimum of 5 posts.
Dead center of my Trophy room I have a Pillar which has a steel beem for structural support and I will make use of the pillar by using a wall mounted bracket to fix the projector to it.
From the pillar to where the screen will eventually be is exactly 6.65 meters however once the projector is mounted to the bracket it will be about 6.1 meters (20 feet) away from the fixed screen.
Also I thought it would be worth mentioning that the seating will be approximately 5.5 meters (18 feet) from the 150 inch screen.
If all goes to plan and weather permitting my cousin who is a Electrician will pass all the cable this weekend. He just purchased some CAT-6 & RG6/RJ6 cable today.
Also unfortunately because each run of cable needs to be between 25 to 30 meters (82 to 98 feet) long.
I cant go HDMI as I have been advised that once HDMI goes over 15 meters long, it starts loosening its Audio & Video signal.
I have been advised to go with Cat/6 and then use a Gaffen Toolbox HDMI extender over the Cat/6 cable to then change the signal to HDMI where it counts.
At first I was looking to purchase the following items which I have listed below:
Optoma HD83 or HD8300 projector (I LOVE 3D MOVIES)
Integra DTR 70.3 Amp
Oppo BDP 95 Blu-Ray
150 “ Majestic Fixed frame screen, with Evo 3D fabric. Aspect ratio 16:9
Gaffen Toolbox HDMI Extender over Cat/6 (Extra long range Extender for HDMI, 3D TV and IR over one Cat-6 cable)
2 Audioquest premium Pre-terminated speaker cable + Premium Audioquest connectors Pre-fitted (This is to Bi-wire my Front B&W CDM 9NT Speakers)
3 Audioquest Pearl HDMI cable. High speed with ethernet 1 meter each.
$11,250 here in Melbourne Australia.
I thought I would make a call to a A/V shop here in Melbourne Australia probably one of the best A/V shops here. I actually purchased my very first stereo system which had Lazer Disc, this was 21 years ago, unfortunately Lazer Disc never took off, the sound was awesome and these guys were very helpful although anyone would be when spending $10k for a stereo system 10 years ago. However they really went out of there way I felt to help me out.
After calling them and emailing them a list of what I was looking at purchasing as I done above, he mentioned straight away that because my room is so large and has basically ALL hard surfaces he thought TWO things should change from the list due to my room, he mentioned a NAD Amp would work better for my Trophy room and sound better then a Integra Amp, he stocks Integra and I knew he does as I checked there site, he said they are a AWESOME amp for a dedicated home Theater, his point was because my room is full of hard surfaces he suggested that there are a couple of NAD amps that would make the sound much better then what a Integra Amp would due to the way my trophy room is.
Secondly he was against Optoma projectors, he said that Optoma make a great projector if you happen to get a good one but he said that there customer support was shocking, to the point that if something went wrong with the unit that Optoma would take from 1 month to 3 months to fix the problem and told me straight out if I wanted a Optoma projector that he wouldn't sell me one because if anything went wrong with it then I would obviously have to go through him to get the issue resolved. I know it may come across as him being rude when reading it in text, but I really appreciated his advice, as he said he can get me one, but it's something his company no longer deal with due to there poor customer service here in Australia.
Now I totally understand that everyone is going to have certain opinions and preferences when it comes to Amps and Projectors or anything for that matter.
My main query right now is, Can the brand of Amp such as going from a Integra Amp to a NAD Amp really make a huge difference in sound to a room such as my room as it isn't acoustically designed as a theater room.
Regards and ALL advice will be appreciated greatly.:help:
Dean
Hello and welcome to HTS. Look forward to seeing your subwoofer system to pressurize that room. :D
That is a very quirky room Dean. :rubeyes:
I look forward to see how your system progresses.
BTW it's a bit warmer up here in Ncle, Not so close to the antarctic. :whistling:
Cheers,
Bill.
Sorry I should have warned people if photo's of stuffed animals offends please avoid entering but I honestly thought my photo's wouldn't load up. I wanted to add the photo's as they show the Pillar where the Projector will be mounted and also the rock wall is where the screen will be mounted.
I'm really not sure whether to go for a decent NAD Amp or stick with the Integra DTR 70.3?
Also what is a GREAT 2D & Awesome 3D projector?
Cheers
Dean
Dean,
As far as the projector, I would take a look at the new Panasonic AE-8000U. The AE-7000U (the previous model) is also a 3D capable projector, but one of the biggest complaints with it was that it did not have enough lumens to function well as a 3D projector. From initial reviews, they look to have corrected this issue.
As far as the processor, that is going to be a big space to fill as well as having some odd angles. I set up a system in my living room that has an open floor plan with vaulted ceilings. I went with the Sherwood 972 which uses Trinnov - it seems to handle measuring and adjusting the odd room configuration of the room much better. It does have it quirks - there is a thread here providing many people's experiences - but I have been really pleased with it's ability to calibrate my odd-shaped room.
You only mention your two front speakers, what, and how many surround speakers are you planning to run from the 70.3? That would really be more determinant of a need for an external amp or not. I personally do not subscribe to the "sound" of an amplifier when we are talking solid state.
The 70.3 is a good choice, comes with XT32 which will help a bit in that space but room correction software can only take you so far. You will need some room treatments in there to minimize reflections. The dealer you are working with sounds ok but anyone that recommends an amp right out of the gate to solve for some very challenging acoustic space issues would not be my first choice of partner to work with. He should have offered up some advice on how to treat the room first then worry about how to best drive your speakers once that issue has been dealt with. Perhaps put very heavy coats on all of your friends in there? :)
Just kidding, but since you already have a good deal of wall ornamentation you could get creative and place the mounts onto some acoustic panels. Good luck with the project and have fun with it!
Welcome to the Forum. Have fun. Dennis
Sorry I should have mentioned more info about my speakers. Currently my set up is 5.1 but I will be passing or adding speaker cables to make it true 7.2 set up, thats the best I can go due to the existing speaker wire I have run in this room. I could go 9.2 but that would mean having exposed wires in my room and thats something I cant stand.
I think by going 7.2 and having 2 extra side speakers will help a great deal and while passing all the cable it will take no extra time to pass some RG6/RJ6 cable in order to have my second Sub-woofer behind my seating area directly on the floor somewhere.
I just thought of this but I don't know if this would help anything Re: Audio in this room.
I could get some good quality speaker wire and run it down my Pillar. The bottom 1.1 meters (3 Foot 7") of the Pillar widens out to be 1 meter mide (3 feet 3" wide)
If you think having 2 extra speakers either side of the 1 meter or (3 feet 3") wide part of the Pillar directly behind the seating area will help with sound then I'll be more then happy to run the extra speaker wire there and add 2 extra speakers either side of the widest part of the pillar. Would it matter that it's only 1 meter wide or 3 feet 3 inches wide?
The 5.1 speakers system I currently have are all B&W.
The fronts are floor standing B&W CDM 9NT
The centre speaker are B&W CDM CNT
My rear speakers are B&W CDM SNT (Wall mounted)
The Sub-woofer is a B&W ASW-675
The A/V dealer that recommended I should strongly consider a NAD Amp over the Integra 70.3 did mention to me prior if there was anyway I could soften the room and explained to me how sound keeps bouncing off hard surfaces so to speak, I couldn't believe how complex sound actually gets, it's truly amazing.
However as I described to him because I designed this room as my Trophy Room I cannot really do anything to soften up the walls or ceilings. The best I can do is run rugs on the timber flooring and he said that would defiantly help to a degree.
Hope the added info I explained helps you a little more.
Thank you for taking the time to try help
Dean
Thanks allot on the information you provided, I will look into the Panasonic AE-8000U
As for the Amp it's a tough decision but all advice is appreciated.
I wonder if some of the larger trophys could be strategically placed around the listening area and used as absorbtion panels. That and a rug between the seating area and the front speakers.
Honestly the only reason I can see why a Nad would sound better then a Integra unless you going with full separates for power reasons. I would think the Audessy eq in the Integra would be benificial for you.
If you planning on putting your rear and side surronds on the actual side and rear walls they would be considerably further away then is recommended, but if that is a want/need then I can see that you would want larger surrounds and the extra power separates would give you. I take it speakers on stands closer to the listneing area is not wanted because of cables on the floor. Also I wouldn't bother with dipole surrounds considering the trophys on the walls.
If warrany is an issue downunder for the Optoma then go with the Panny
Discussion Starter · #13 · (Edited)
I sincerely appreciate everything you have stipulated. I really like your idea about re-positioning the full mounts by moving them forward to where the sound is basically focused, as that is something that would be very easy to accomplish.
Regarding my rear CDM SNT (Wall mounted) speakers, they are not placed right at the back of the room at 14 meters or 46 feet. The rear speakers were mounted on my wall about 3 feet behind the seating area which is 6.1 meters or 20 feet from where the Screen will be.
Once I looked at it and got a mate to measure a couple of things, the rear speakers will be dead in line to where the projector will be mounted, obviously the rear speakers are mounted to either side of the side walls so they are 5 meters or 16 feet per side away from the projector. To give you a better idea on how I envisage my speaker layout to be I made a quick list below.
(1). Two from speakers either side of the screen which will be 3.5 meters wide or 11.5 feet wide.
(2). First sub-woofer to one side of the screen or directly below the screen under the stage.
(3). Centre Speaker dead centre of screen, just below the screen.
(4). Two side speakers 3 meters or 10 feet back from the screen.
(5). Rear speakers 6.1 meters or 20 feet back from the screen and about 1 meter or 3 feet behind the seating area.
(6). Second sub-woofer directly behind the seating area.
I would like to mention so far we have NEVER really been able to enjoy the audio while watching a movie in this room.
When ever we watch a movie in here, I promise you that every 10 minutes or so someone or other will ask "What did he/she just say" and it's beyond frustrating.
However I must mention I have not used a digital Receiver/Amp in this Trophy room as yet, all I have used is my analogue Receiver/Amp which makes me wanna cry when I remember paying $6,000 for it ten years ago but I guess this will continue to happen due to technology regardless of the amounts we spend.
My real query and slight concern is how true is this Re: Digital Receiver/Amp will make the Audio & Video so much clearer, I have been told over & over that the analogue Rec/Amps are chalk & cheese apart when comparing them to a Digital Rec/Amp.
It scares me still, firstly and foremost because I have never been able to hear a quality Rec/Amp in this room, secondly I don't want to spend $10k to $20k if the digital Rec/Amp isn't going to improve the Audio enormously.
I want to make sure I am very clear when I use the word "Audio"
The only audio that sounds poor and is frustrating in this room while watching a movie, it's the voices of the characters that's shocking and are very annoying at times. The rest of the sound system sounds AWESOME.
Lets face it when you have problems hearing what the actors are saying at times, theres nothing worse while watching a movie.
Do you think it would make a great deal of improvement when it comes to hearing the voices of the characters if I chose to have two quality centre speakers rather then just the one centre speaker?
Cheers
Dean
Cheers
Dean
IMO, you will be extremely pleased with Audyssey (or the calibration software for whichever AVR you choose) as it will be able to determine what levels your speakers need to be at. Once the calibration is done, if you are still having issues with hearing dialogue, I would suggest increasing the output level for the CC through the speaker level menu.
Plus, it won't cost you $10k to get a quality unit with the newest version of the calibration software. :clap:
I have chronic tinnitus and have a miserable time with voices in movies. Since so much of the soundtrack and vocals are reproduced by the centre channel I believe it is the heart and soul of a theatre system and I purchase what I personally believe is one of the best without breaking the bank (Axiom VP180, however, my entire system is Axiom and my mains have the same drivers as the CC). I ran Audyessy and then boosted the CC 3 notches which works for me. Your current CC may be enough or I may not, prior to replacing or adding another I increase its output to the point where there isn’t a problem hearing the vocals and if at that point your finding the speaker is sounding strained (distorting) then look at an upgrade. As for placement of your collection and speakers, experimentation will be the key, such things as:
Raising and lowering the height of the CC and/or surround
Toeing in the mains
Repositioning the sub (YouTube “sub crawl”)
Repositioning your larger trophy pieces
As for the analog/digital amp question, is not the energy supplied by the unit that will make a difference, it’s the processing. Going from Dolby prologic to Dolby True HD is a significant jump imho. That and the need for some type of equalization in your space begs for a unit with Audyessy XT32 and since you will be running two subs Audyessy Sub EQ HT will be beneficial. Of course you can go beyond this automatic EQ and have your system EQed with computers, mics and programs such as REV but that takes a lot of time, patience and knowledge. All that being said if you can find yourself and Integra DRT-80 for a good price you should be very happy.
Another thing to look into is the amount of light you screen will output. Now looking at specs on projector central I see the Optoma HD33 will put out 9fl when placed 20 feet from a screen, however, the Evo 3D fabric is supposed to have a gain of 1.26 which should take the FL up to 12 which is the minimum recommended. But, there is another wrinkle, 3D glasses take away some light which will drop your fl below optimum, the solutions are:
a. shorter throw (smaller screen)
b. higher gain screen
c. projector with a higher brightness
d. leave as is and understand that 3D will be significantly “darker”
Once again thank you so much for your valued information. What exactly do you mean by saying
"I would suggest increasing the output level for the CC through the speaker level menu"
Sorry mate I don't really understand much about the A/V world but find it interesting and if I don't ask questions I'll never know.
Originally as shown in my first post, I was looking to spend around $11,500 for everything such as Projector & 6 pairs of 3D glasses, Rec or Amp, Blu-Ray & cable. Not $10k just for a Rec/Amp.
Thanks again for your ongoing information & Advice
Regards
Dean
Regards
Dean
Sorry, Dean, getting into cold season up here and it knocked me out for a day or two. Andre probably did a much better job than I did explaining what I meant. After running the Audyssey software, you can go into your AVR menu and select something like "Speaker Level Adjustment". Every speaker will be listed and you then have the ability to increase the output level of each speaker individually. It is here that I would suggest increasing the Center Channel.
Discussion Starter · #18 · (Edited)
Sorry to hear you caught the cold, I caught a nasty dose of Bronchitis 3 weeks ago and after a week of trying to fight it, I had to admit myself in hospital, thankfully I was only in for 2 days and getting better each day.
I hope you guys don't end up getting this nasty strain of Bronchitis that hit all of Australia pretty bad.
That sounds AWESOME and if that is all that is needed then I will be one very happy man. I know that once I purchase the A/V system it will include a full calibration although I have a mate who is right into A/V and when I had him over in my house for the first time he mentioned he could do something with each indervidual speaker volume.
I know with the Integra AVR 70.3 Receiver I was looking to purchase, I was told it comes with a microphone and some software so it calibrates your speakers for you. Is this Audyssey software the same sort of thing?
Does this Audyssey software run on ALL Receivers & Amps and all speakers? Where can I purchase this AUDYSSEY software & how much does it cost?
On another subject I got two A/V systems to chose from at the moment. I have made a full list of the two 2 systems below, sorry to repeat myself mate but any advice would be appreciated.
What A/V system would you recommend. So far the only unit I know I will be getting is the Oppo BDP-95 Blu-Ray the rest im not sure about.
I have to mention Yesterday after 10 long hours my cousin & father fully wired my trophy room. I added much more cable runs then I actually needed but thankfully now its done.
#: 1 A/V System
1 x Optoma HD83 Full HD 3D Projector. (Includes 2 pair of glasses)
1 x Optoma Genuine replacement lamp to suit HD83
4 x Glasses
1 x Ambertech G-2 Projector Wall mount
1 x Integra DTR 70.3 Receiver
1 x Oppo BDP-95 Blu-Ray/DVD/CD Player
1 x 150" Majestic fixed frame screen, with Evo 3D fabric
1 x Gaffen Toolbox HDMI extender over Cat-6
1Pr x Audioquest Premium Pre-Terminated Speaker cable with Premium Audioquest connectors pre-fitted
3 x 1m Audioquest Pearl HDMI Cable
1 x Labour - Visit site, make connections, preform room calibrations for Audio & Vidio
System Price $11,252 AUD
#: 2 A/V System
1 x Sony VPL-30 Projector (Includes 2 pair of glasses)
4 x Glasses
1 x Flexmount Projector Mount
1 x NAD T777 AV Receiver
1 x 150” Screen Technics Matrix Fixed Screen
1 x Binary CAT6 HDMI Baluns
1Pr x Transparent The Wave Speaker Cable
1Pr x Transparent The Link Interconnects
3 x 1m Wire Chroma 6 HDMI cables
1 x System Installation & Calibration (Based on up to 8 hours on work)
System Price $13,600 AUD
Regards
Dean
Yikes! Glad to hear you got everything cleared up.
That is the great news - most new AVRs are coming with this included - as a matter of fact, the Integra 70.3 has Audyssey XT32 on board which not only does a great job with speakers, it does well on subs too.
#: 1 A/V System
4 x Glasses
#: 2 A/V System
4 x Glasses
Regards
Dean
Choosing between the two options, I would probably go with the first - fir me, it really comes down to the Integra versus the NAD. I would take the Integra as it has XT32.
As Joe stated the Audyssey calibration system is part of the software included with the Integra.
If I may I would like to edit your AV “1” list with these changes
1 x Panasonic PT-AT6000E (or the 7000 if you buy US)
Review: http://www.expertreviews.co.uk/projectors/1294366/panasonic-pt-at6000e-review-hands-on
Reasoning: Your dealer said Optoma has customer service issues in AU. Additionally, placement/adjustment may be more difficult due to minimal lense shift adjustment and manual focus of the Optoma. Panny is also brighter which is a benefit to 3D viewing
With the Panny’s Lens Memory function you can go from a 16:9 screen to a full Cinescope. http://www.ozts.com.au/cinemascope.htm
If you don’t need the IR extension you can go with the Gefen HDBaseT extender and save some $ http://www.gefen.com/kvm/dproduct.jsp?prod_id=10870
I am an atheist in the religion of high end cables. The Gefen units come with cables and will be fine, saves you some $ (just check on the cable if they are 1.3 compliant)
Does the calibration in the labor include an ISF certified calibration of the projector and receiver? http://www.ehow.com/about_6647292_isf-calibration_.html
A universal remote URC (Universal Remote Control inc) Digital R50 is a nice one
remote control light dimmer http://www.lutron.com/Products/Stan...-Switches/MaestroIRDimmer/Pages/Overview.aspx
Because of the size of your room I will recommend a second sub if it is within your budget. The SVS PC13 Ultra is a cylindrical sub that is easy to move around (did you look at the "sub crawl" video?) and looks cool to boot. http://www.hometheaterhifi.com/volume_14_4/svs-pc13-ultra-subwoofer-12-2007-part-1.html
What did you cousin/father wire your room with?
1 - 20 of 35 Posts
