G
Guest
·Hi! I have the following specs:
Denon AVR-589
Energy 5.1 take classic speakers (8 omhs) (4 small speakers 100W, 1 center 100W, 1 SW 200W)
Samsung Blue ray 1500
Wanting to have a little more "punch" with sound, I decided to buy an additional center speaker (Polk Audio 180W 8 omhs).
My question is the following:
May I connect Polk audio center at same place than Energy center (behind avr/589 under "center speaker"?
Another option would be to connect it under section "B" on avr back panel (right or left). However, under the setup guide, it says at page 9 under "note" that "... When using front A and B speakers simultaneously, use speakers with and impedance of 12 to 16 ohms". Since I only have 8 ohms speakers, is there any danger of breaking them?
Sincere regards,
Daniel
Denon AVR-589
Sincere regards,
Daniel
