1 - 5 of 5 Posts
Hello All!
First off, I'd like to commend this forum and members for the abundance of quality knowledge!
So here's my project/dilemma. I have a pair of USD audio waveguides A-700 that I had in my car (got broken into and all of my components were stolen...luckily the bastards didn't see the horns) and would like to create a HT starting from these waveguides. Do any of you have any experience setting up such waveguides for use in HT? How would they sound if connected to a AVR or pre/pro + power amp?
I also would need to get some mids to accompany these waveguides. Do you think it's wise/worth it to make a custom box that will enclose these waveguides with some mids speakers? I wonder how these would sound...
In the long run, insisting on using these waveguides may create more work but I would like to see how they would sound in HT rather than just selling them. Of course the acoustics of a >2500 cu ft great room are completely different from the small enclosure of a car but these waveguides sure sounded great in my car and I guess my curiosity is getting the best of me haha.
Any help would be much appreciated!
Cheers,
Naru177
Welcome to HTS, Naru177!
We need to know the what the dispersion characteristics of the horn are, then match this to the dispersion of a good midbass driver at the crossover. At 110 dB sensitivity, you are going to have to pad that bad boy down. An 18" wide horn is a bit unwieldy.
I am going to move this to the DIY forum to get you more exposure to members that can help you best.
Welcome to the Forum. Have fun. Dennis
Thanks for replying and forwarding the thread to an appropriate location :)
So I don't know the specs of the dispersion characteristics but here are the specs of the horns:
The USD Audio A-700 WaveGuide sets a new standard for reproduction accuracy in a horn loaded compression driver.
Key features of the USD Audio WaveGuide A-700:
1" Compression Driver
1.75" Aluminum Diaphram
RotoMount
Frequency Response: 800Hz to 20kHz
Recommend Crossover Frequency: 800Hz.
Power Handling: 100 watts RMS
Sensitivity: 110dB 1w/M
Nominal Impedence: 8 ohms
Size: 2.5" high x 18" wide x 10" deep
Magnetic Copper Shorting Ring for improved high frequency performance
WaveGuides provide improved sound, imaging and staging with:
On axis response with minimum Pathlength offset. Just like your home stereo, the speakers are facing you - not each other.
Patented Design.
The unique AccuCurve™ Len returns lower distortion than any other horn loaded compression driver (HLCD), while Improving frequency response and power handling.
Radical "Recurved" Guide Body - Improves Imaging and Staging.
World Class manufacturing Techniques like High-pressure Injection Molding insures consistent quality of the WaveGuides. WaveGuides are Easy & Fast to install:
Definitely eager to the fun started :) Thanks again!
Hello,
Welcome to HTS and best of luck with your Build.
Cheers,
JJ
1 - 5 of 5 Posts
