1 - 8 of 8 Posts
Thanks for all the welcome messages !!!!
Maybe this has already been discussed but ...
I am not very familiar with the REW system since it is not used in professionnal environnments.
(i am a recently retired sound engineer)
Could someone point me in the direction of a site or page where i could learn about it from scratch :scratchhead:
I know what it is supposed to be and to do, but i want to learn how to implement it and use it
Again thanks for the warm welcomes
Philippe Paris, France
Welcome and thanks for joining us! Please visit us often.
You will find REW to be a great tool. Its learning curve is a bit high for some of us, but I suspect that you are familiar with a lot of the terms based on your previous work history.
Thank you hjones4841,
i will have a close look to it when i have enough time.
Would you know a thread where someone from this forum explains where he started from and used REW to equalize his room, giving before and after measurements ?
Also, i suspect that a bit of "real" treatment should help, to what extent ?
Philippe
Super Moderator
Here’s a good example:
Spridle’s Experiment
Treatments are intended to minimize reflections and reverberation, and have little to do with equalization. For instance, if you have a “live” room with a lot of hard surfaces, it has a lot of reverberation because the signal reflects and bounces around all over the place, and takes a long time to fade away. Anyone will tell you that an equalizer is no cure for a "live" room, nor is any other electronic device. That requires absorptive treatment, furnishings, etc.
Don't get me wrong, the equalizer is a great tool for what it does. But you have to know and respect its limitations. :T
1 - 8 of 8 Posts
