so what is the best option the 1259 or the cv?
i havent realy got room for 10 cu ft lol
I did look at a jbl 1514
REVC (OHMS) 3.80
VOICE COIL
[email protected] 1KHZ: LEVC (MH) . 3.05
DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 128.7
SD (M2) . . . . . . . 830.00
MOTOR FORCE FACTOR: BL (TM) . . . . . . . . 17.13
COMPLIANCE VOLUME: VAS (FT3). . . . . . . . . 5.42
VAS (LITERS). . . . . 153.50
SUSPENSION COMPLIANCE: CMS (μM/N) . . . . 156.00
MOVING MASS, AIR LOAD: MMS
MD
(GRAMS) . . . 257.00
MOVING MASS, DIAPHRAGM: M (GRAMS) . . . 243.00
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 25.10
QMS . . . . . . . . . . . 7.08
QES . . . . . . . . . . . 0.52
QTS . . . . . . . . . . . 0.49
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . . 0.31
HAG (MM) . . . . . . . . 8.00
VOICE COIL HEIGHT: HVC (IN) . . . . . . . . . 1.45
HVC (MM). . . . . . . . . . 37
MAXIMUM EXCURSION: XMAX (IN). . . . . . . . .0.57
XMAX (MM) . . . . . . 14.50
mounting depth
6-13/16" (172mm)
cutout diameter
13-15/16" (354mm)
outer diameter
15-5/16" (389mm)
cheers andy
