Sketchup design.
A little over 3 cubic feet. 30" across, a little less than 18" deep and tall. MDF with bracking. Packed with poly-fill.
Probably going to use glue and pocket screw joinery on the inside with shallow dados on the bottom and front baffle for the bracing to stiffen it further.
Not sure where I'll put the terminals or cup yet. Should all be doable with one sheet of MDF.
