C
CharlieSpoons
·Guest
Hi folks - Happy New Year,
I'm a noobie and just about to dive into room acoustics for the first time!! My listening room is in the top floor of the house as a roof conversion. So 2 of the walls are sloping – see .jpg. Actually I use the room for films as much as for 2 channel music not sure how that changes things? none of the walls have a solid base except for end wall (see "screen" end) which is brick with plaster (rock) board covering.
The listening room is about 13Feet by 12 Feet – see bedroom 1 above.
Most of the rooms I see on the web are square, mine isn’t and so my question is what is the best way to determine what I need to remove first reflection points (what effect will the sloping walls have?) and corner base traps.
Thanks for your help!
