1 - 5 of 5 Posts
Noob to the REW forums...greetings :wave:
I have some basic ext usb soundcard questions.
Planning to purchase the Behringer ECM8000 together with the Focusrite Scarlet 2i2 external soundcard and relevant cables.
To ensure I procure the correct cables the first questions I have is relevant to hookup cables.
The Behringer ECM8000 mic has a XLR output where the mic input on the Focusrite appears to be something like a Neutrik speakon type (this is new to me). Is their adapter I need to purchase that converts XLR to the mic input on the Focusrite or can I purchase a standard microphone cable with XLR on one end with the Focusrite mic input type connector on the other?
I believe that the TSR 1/4 line out is connected to a line input on my av processor (rca connection). Do I need to purchase an adaptor or can I buy a cable with TSR 1/4" on one end and rca on the other without incurring hum challenges? Recommendations?
I believe I also need to loop output #2 (TSR 1/4" on the Focusrite) to input #2 on the Focusrite which I believe is the 2nd mic input with the strange (to me anyway) neutrik type connector. Please could you recommend a cable to undertake this?
Lastly, I believe the Focusrite connects to my laptop via usb.
Thanking you in advance your answers and for being patient with typical noob questions. Just want to ensure that I have everything to get me started :T
Greets !
(1) INPUT: The mic cable used ( with the Focusrite 2i2 ) will be with a regular 3-pin XLR cable .
(2) OUTPUT: The cable ( connecting the 2i2 to your AVR ) needs to be a, 1/4" TRS to RCA ( a 1/4" TR to RCA can also work ) . Check Amazon for likely candidates .
- If you get "Hum & Buzz" when this connection is made, then run your laptop ( if applicable ) off the battery when making measurements .
(3) LOOPBACK cable: a 1/4" TRS to 1/4" TRS cable links output to your unused input . The 2i2 uses a "combo input connector" that accepts either XLR or 1/4" .
(4): Soundcard Connection to your computer is via USB .
:sn:
Super Moderator
As Earl noted, the strange-looking input connector is a combo jack that will accept a standard mic cable.
There is no such thing as a TRS to RCA cable, as far as I know, because it’s pointless. Even if you can find one, it will be the functional equivalent of a TS to RCA cable, so don’t waste your time scouring the internet trying to chase down the former. TS plugs work fine in TRS jacks like the Focusrite has.
Wayne and Earl,
Thank you both for your replies; this was extremely helpful.
One more question:
The loop back cable from output #2 on the Focusrite 2i2 to input #2 on the Focusrite, ideally, does this need to be -
* 1/4 TRS to 1/4" TRS
or
* 1/4" TS to 1/4" TS
Many thanks
1 - 5 of 5 Posts
