1 - 8 of 8 Posts
What is the material that you could put inside of your speaker to dampen the resonances?
I have seen some white cottony thing, but I don't know what material that is
Please help
Stuffing used kind of depends on the enclosure. What are you using it for specifically?
Im cheap, never robbed my pillow of stuffing before ...however I may now.
The stuff you are asking about is called poly-fill. Parts Express carries it. It is a bit better than cotton or other dense poly filling that would be in a pillow.
Good luck.
Do your cabinets actually have resonance? Are they sealed or ported? Do you really want cabinet dampening or are you trying to control the bass response, i.e. like the cabinet is to small for the woofer specs?
1 - 8 of 8 Posts
