Looking for a budget system, preferabley build my own but HTIB I guess if its upgradeable. dont care if its 2.1 for now for I want the best bang for the buck and can always upgrade. Looking for something that sounds good for not only movies but the stereo/cd's. Would like a reciever/speakers/and CD player. Do not at this time have a blue ray or DVD player worth a either so if possible would like that too, if works as CD player then wont need that the DVD/blue ray would work. What are my best bets for around a grand?? I've heard the avs systems are good and reasonabley priced also the Yambeka 5-speaker system. But as I said I dont need the 5.1 as of yet unless it fits in the budget. Would rather spend more on two speakers and a center. Would also like to add 2 speakers on another channel for the patio, nothing fancy just so have music there for BBQ darts etc... Thanks guys
If it helps have a 61A650 on the way and Time warner HD/DVR,
Old school Pioneer Reciever
thats about it everything else is junk.
Thanks again!!
Thanks again!!
