1 - 13 of 13 Posts
Below is a list of Normal convergence failure components courtesy of SLR_65 :T
_________________________________________________________________________________________________________________
PT-56WX53G
Hi Guys,
As I come across info on various models I thought I would post it here for handy reference.
I have not personally worked on this set or confirmed this info with the service manual so before you order parts please take a moment to find a manual for your model and confirm these part numbers and values are correct!
Normal Convergence Failure Components:
(2) STK392-110 Convergence ICs
(6) 2.2 ohm 2watt resistors - R7011, R7012, R7013, R7014, R7015, and R7016
Hope this helps!
Steve
Discussion Starter #2
PT-47WX53G Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
PT-47wx33G Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
Discussion Starter #4
PT-47WXC43G Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
Discussion Starter #5
PT4743G Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
Discussion Starter #6
PT-47WX42 Normal Convergence Failure Components
Hi Guys,
(6) 2.2 ohm 2watt metal film resistors - R7048, R7049, R7050, R7053, R7056 and R7059
Hope this helps!
Steve
Discussion Starter #7
PT-47WX42CF Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
Discussion Starter #8
PT-47WX42F Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
Discussion Starter #9
PT-47WX51E Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
Discussion Starter #10
PT-51HX41 Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
Discussion Starter #11
PT-51HX41CE Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
Discussion Starter #12
PT-51HX41E Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
Discussion Starter #13
PT-56HX41CE Normal Convergence Failure Components
Hi Guys,
Hope this helps!
Steve
1 - 13 of 13 Posts
