61 - 67 of 67 Posts
Super Moderator
The movie industry has their own version of what a house curve should be, that suits their purposes.
For instance, they may be reducing below 63 Hz to minimize low frequency bleed-through to adjoining theaters.
Again, the X-curve discussion was only meant to show that house curves are necessary both in production and playback. The X-curve itself is of no use in a home theater, unless one happens to prefer sagging lows and highs.
Discussion Starter #64
I guess that is where I get a little confused. I figured since the movies are mixed to the x-curve, that trying to match would be a good idea. Then I thought that since a house curve is boosted in the low end that it was trying to compensate for that drop.
Still a little confused but I think I am getting it.
Super Moderator
Nope – the house curve is merely a compensation for your particular room – has nothing specifically to do with movies, actually, because you probably need one even if you only listen to music. :)
Discussion Starter #66
Thanks again, Wayne.
So, does that mean if a person listened to a speaker (and the speaker measured flat) in an anechoic chamber, it would sound good? And the only reason for the house curve is to compensate for the room acoustics?
Super Moderator
Couldn’t say – I’ve never heard a speaker in an anechoic chamber. :)
Well, now you’re getting into areas I really don’t know much about. Acoustics has more to do with a room’s reverberation, or lack thereof, and perhaps treating to minimize the same, if needed. A house curve seems to be related primarily to the size of room, and when you include the mids and highs, your physical distance from the speakers. As I noted in Part 2 of the house curve article, I’m more familiar with the “how” than the “why.”
61 - 67 of 67 Posts
