1 - 1 of 1 Posts
Known for high quality power amplification, NuForce has created its own brand and niche in the market. With great sounding amps and products, this system designed for your desktop, where a computer sits, is a great answer to someone seeking a system, but lacks space.
NuForce Icon / S1 Amplifier Reviewed
By: Brian Kahn - Reviewer's System
Category: Audio Reviews, Bookshelf Speaker Reviews, Equipment Reviews, Stereo Amplifier Reviews
Resources & Links: NuForce
November 8, 2008
Email To a Friend | Print Page | Adjust Font Size:
Get the Home Theater Review Weekly Newsletter...
Email Address: *Required
Email Marketing by VerticalResponse NuForce has made a name for itself over the past couple of years by producing switched power supply amplifiers that have been getting rave reviews. One of the benefits of a switched power supply amplifier is that it can be much smaller than a similarly-powered conventional amplifier. This allowed NuForce to create the Icon, a 12-watts-per-channel integrated amplifier the size of a paperback book. The heart of the Icon is NuForce's own Class-D amplification circuit. The S-1 speakers were designed to accompany the Icon, the Icon and S-1. Each retails for $249.
The six-inch by 4.5-inch by one-inch Icon weighs about a pound and is housed in an aluminum case that can be had in four different colors. The tiny Icon has two knobs on the front panel: one for choosing between the RCA, USB and 3.5 mm inputs and the other for volume. The back panel has the above-described three inputs, a power jack for the supplied wall-wart power supply, headphone output, subwoofer line level output and a pair of Ethernet jacks. The Ethernet jacks are the speaker outputs. They work well. Also included in the box are a stand for vertical mounting of the Icon and two pairs of cables. One pair comes with RJ-45 plugs on both ends and is designed to work with NuForce's S-1 speakers and the second pair has RJ-45 plugs on one end and banana plugs on the other end so that you can use speakers of your own choosing.
The NuForce S-1 speaker is a diminutive waveguide speaker, featuring a single 3.5-inch titanium full-range driver. The driver was engineered by NuForce and has a die-cast basket, vented pole coil and a neodymium magnet. The driver is set into an enclosure 9.5 inches tall, six inches wide and 4.75 inches deep, weighing 5.5 pounds per side. The speaker's waveguide controls dispersion, reduces cone excursion and increases efficiency.
Listening to the system on my desktop, I had the speakers a few inches from the wall and about three feet from me. This system benefits from the bass reinforcement from the wall and sounds best with the listener in the near-field position. I found the Icon/S-1 system made a good desktop system that was able to handle a variety of sources and provide great bang for both the buck and the size.
High Points
• The versatile NuForce Icon can be used as preamp, headphone amplifier, USB DAC or a low-power amplifier at low cost in all sorts of creative applications.
• The Icon's compact form factor allows great flexibility on today's already overcrowded desks.
• Sonic capabilities are well beyond that of most desktop systems. Quiet, powerful and way beyond the scope of computer audio sound only starts to describe the NuForce Icon.
Low Points
• The NuForce Icon requires an outboard box if you insist on using your own non-RJ-45 terminated cables.
• The Icon's relatively low power makes it difficult to fill a medium-sized room for anything other than background listening. For most desktop situations, there is more than enough power, but if you want to light up a pair of MartinLogan's with the Icon, it might be a little underpowered.
Conclusion
This is a great system for someone who has limited space for an audio playback system, yet still wants better sound than the typical desktop stereo system can offer. If your room configuration does not allow for placing the S-1s in a position where they can receive bass reinforcement from a wall or partition, you may want to consider another pair of speakers.
1 - 1 of 1 Posts
