1 - 14 of 14 Posts
Ok, well ohms law didnt really fail but I have a pair of car audio component speakers that are 4 ohm each.
I wired the crossover input wires in parallel and got a 2 ohm load. When I wire it in series, it is still 4 ohm, not 8 ohm...
Any help?
with a multimeter set to 200 ohms range
each comp separately was 4.3 ohms
series was 4.6 ohms
parallel was 2.3 ohms
You are reading DCR ( DC resistance ) not impedance.
This is a common mistake.
AC and impedance involve the addition variables of frequency and phase.
DC resistance is commonly 60 - 80% of impedance.
But speakers are reactive elements, so their impedance varies with frequency.
Often impedance values are stated at a given standard frequency of 1000Hz.
Syd
But how come when I measure my subs in DC, it reads like normal?
And how could I measure actual impedance?
So, can I just hook up the speakers to my receiver and play a certain sine frequency and then measure the ohms? or will that somehow mess up the receiver?
Plain ole user
The resistive component should still add. You are either not wiring in series like you think or you are measuring at the wrong points. You may also have a load in the crossover altering your reading.
both crossovers have tweets and mids attached to them and I wired them + +- - and tested ohms on the left + and right -
They do add, they increase by .3 ohms...
When I just do the mids or tweets, I get a higher "correct" reading.
Now what do I do about the two crossovers?
Can I wire both mids and tweets through one cross over? Will the cross be able to handle the power?
Any help?
Wouldn't you only have one crossover input wire per output?
I'm not a car audio guy, but the crossover simply distributes the correct frequency range to the speaker components. This is almost always done in parallel. But you only get a parallel load if you have dual drivers on one of the frequency ranges.
No, never do that, you'll probably bust your receiver or give it a very very hard time of it's life :eek:lddude:...
Try using speaker workshop, it measure impedance using your sound card's line in/out and a ref resistor
1 - 14 of 14 Posts
