Well I did check out the Whisper clips for the Hat channel and most likely will be buying them.
onder: I did a little tinkering and designed my own set sort of. What I did was cut strips of EPDM rubber 1.5" wide by 4" long @ .25" thick and will install under the Hat channel to the floor joist's. Also I made EPDM washers to isolate the screw head from the Hat channel and a steel washer. So essentially the Hat Channel will have the ability to move ever so slightly. I know this is not a tested method but what do you think? I know it will be secure so the sky won't be falling.lol
