Hey guys, thanks for all the advice and information you've gathered here. Just wanted to get that out first.
Ok, now my question is this...
I've decided to spend around $2k. I decided to go with the Onkyo 805 and the SVS speakers. The SBS 5.1 package with the 10 inch sub to be exact. I've seen this set-up recommended before as it all sounds like great quality for the money.
This will be the first time setting up any type of surround sound. Is it a complicated thing to do? Lot of words and phrases floating around the forums that I can only guess at. I heard that there is a way to automatically set things up with the 805. Next concern is to make sure that the 805 has enough hook-ups. I want to run a cable box/ps3/wii through it. The first 2 use hdmi and the wii uses component. Will there be any problem with this?
Thanks for all the help.
Apollyon
Apollyon
