1 - 20 of 36 Posts
Thought that I could share few pics of my monoblock project from last fall.
Modules are from http://www.newclassd.com/index.php?page=2&hv=1
including:
- NewClassD NCDX Discrete 480 W in 4 Ohms Discrete Class D Module
- Soft Start Circuit + DC / RFI Filter and power control Combo
- Power Supply Board 10.000/63 4 layer with Ultra Fast Recovery Diodes 4 wire
- Toroids 2 x 42 VAC 1000VA
Enclosures+feet from ebay. Connectors and inner cabling from ebay and from my own collection. Painting also my own work.
First test setup:
After testing disassmbled and painted the enclosures for my liking.
Overall costs around $2000 without painting for pair. I am very pleased with the sound, bass is controlled and no interference at all. Toroids make some noise in the enclosure, but when listening music, it's not audible at all.
Awesome build!!! :T :T
WOW !! Ive been drooling over the NewClassD website for over a year :bigsmile: AMAZING work on the chassis !! Jealous as an audiophile can be Sir :drool:
First of all, thank you for your compliments :) I have to say, that I'm still very satisfied with those two. Of course, I don't know any better ones, commercial or diy, so no need for upgrading. And if I'm smart, I don't even think about any testing with other "better" amps ;)
Can you give any details on the paint job ?
Paint job is quite simple in the end. First I laid black acrylic paint (2 component car paint, what do you call it..). I let it dry over night and next day I took red metallic base coat, laid wet coat of it over one panel and after that I "broke" the paint with cling film. Rubbed it around and tapped with it, so I got that structure to look like, well, maybe marble (not quite), but some little more "expensive" look than anodized aluminium.
Finally lots of clear coat. I was planning to polish it at the end to get rid of the imperfections, but I got lazy and forgot it.
Corner parts are painted with that same black acrylic paint and front and rear panels are painted with that same metallic red.
Now I have also painted the DIY preamp and Audiolab 8200CD -player with the same theme. Fronts are red and sides/tops are painted with that "special" recipe.
OT:
Audiolab:
Relaixed preamp:
Discussion Starter · #14 ·
Same seller had/has also those aluminium feet, which I have with those enclosures. Looks better than the rubber ones which comes with the enclosure and are easy to install with two sided acrylic tape. Or with screws if preferred.
Discussion Starter · #15 ·
Ya made in China... 2 months for delivery .......
For China quality, these have been excellent enclosures. I ordered one pair to my friend and installed his Hypex modules in them.
For delivery time, first pair for myself I ordered August 14th 2013 and August 31st I had first amp put together for test drive. So delivery time was actually about two weeks. Of course delivery time depends where you are ordering them to be shipped.
Discussion Starter · #19 ·
Did you ever post a review of the Dexa Class D amps ?? Im dying to build some ... but they are quite expensive...
If you meant me, no, I haven't wrote a review. I don't have so much experience with hifi equipment so that review wouldn't be any good.
Love the paintjob!
I found myself more than once wanting to build something like this as well, but always doubted my technical skills as well as my patience to actually finish such a project.
You seem to have the skills for both...:clap:
1 - 20 of 36 Posts
