1 - 5 of 5 Posts
I know my new Onkyo 606 can bi amp speakers. I have a pair of Definitive BP8Bs that only have one set of speaker posts. Is it possible to still bi amp these speakers thereby giving them more watts? I know in a usual setup you are suppose to have a pair of speaker terminals but is it possible with one set without damaging the speakers? Would it then provide 180 watts to each speaker instead of just 90w?
Friend of the Shack
Hi there,
Since your BP8s only have one pair of binding posts per speaker, you won't be able to bi-amp them easily. You'd have to take them apart and separate the crossovers inside. I wouldn't advise doing this, and even if you did, I doubt you'd see much (if any) improvement.
Sorry...
I agree with Otto :yes:
Your speakers are rated for a maximum 200 watts ... so I think is safe to feed them 200 to 250 watts (just don't play them to loud :bigsmile:) and you'll be okay.
It won't be the same as bi-amping ... but you got the idea :yes:
If speakers are not designed to be bi-amped then to try to make them bi-ampable is not a good idea. As Otto said, you would need to change the crossover and other things and it will not improve the sound at all. Bi-amping rarely makes a difference and involves allot more equipment to do it right. Its not just powering the speaker with two separate amps.
1 - 5 of 5 Posts
