1 - 5 of 5 Posts
My 705 remote works sometimes and sometimes not. I called support on Thursday and the guy told me to push a couple of buttons together (receiver and set up, I think?) and it started working again. Now it stopped again.
The problem is that my 1 year warranty expires today, April 1st and they are not open!
Any suggestions?
Any suggestions?
Did you try changing out the batteries(dumb question I know, but just making sure.)
Hello,
Here you go:
You can reset the remote controller to its default settings.
1 While holding down the
[RECEIVER] REMOTE MODE but-
ton, press the [STANDBY] button.
The Remote indicator flashes five
times.
2 Press the [RECEIVER] REMOTE
MODE button again.
The Remote indicator flashes twice,
indicating that the remote controller
has been reset.
Cheers,
JJ
1 - 5 of 5 Posts
