I powered it on last night well tried to, with nothing connected at the back, I pressed the power button and got nothing. When I first plug it in it makes 3 relay clicks, after the 3rd relay click 7 seconds go by then a 4th and final click. None of the status lights next to the power/standby button are lit up at any time. I tried the remote too thinking maybe it was the power button it self but no luck. I guess I have to return it and get another one.
Unless anyone here has any ideas!?!?!
As I said in the PM I sent to you this is unfortunate that you got a bad unit. Have you contacted the place you bought it from?
The 805 should not do what you describe. I hope you get a replacement soon.
Excellent :T Glad you like it.
